kiryen Posted July 30, 2005 Report Share Posted July 30, 2005 I downloaded SonicStage 3.2 a couple of days ago (English version). And I decided to just run it with AppLocale and see what happens. The kanji and kana in titles show up fine. So would I still need to edit the registry? Quote Link to comment Share on other sites More sharing options...
Ishiyoshi Posted July 30, 2005 Report Share Posted July 30, 2005 I downloaded SonicStage 3.2 a couple of days ago (English version). And I decided to just run it with AppLocale and see what happens. The kanji and kana in titles show up fine. So would I still need to edit the registry?←Yes, you do for Japanese/Chinese language tilting purposes. Please refer to this guide for further instruction. Quote Link to comment Share on other sites More sharing options...
kiryen Posted August 1, 2005 Author Report Share Posted August 1, 2005 Yes, you do for Japanese/Chinese language tilting purposes. Please refer to this guide for further instruction.←alright, thanks, i'll try that out... (reformatting my system right now) Quote Link to comment Share on other sites More sharing options...
Christopher Posted August 2, 2005 Report Share Posted August 2, 2005 Please tell us how it went! Quote Link to comment Share on other sites More sharing options...
OCedHrt Posted August 4, 2005 Report Share Posted August 4, 2005 Please tell us how it went! ←I can confirm that Japanese and Chinese (not just Kanji) works fine in 3.2 without any registry modifications for NW-E507. MD's probably still need the registry modifications though, but I can't test how well it works since mine is dead Quote Link to comment Share on other sites More sharing options...
kiryen Posted August 5, 2005 Author Report Share Posted August 5, 2005 sorry for the wait, it's taken me a little longer to do the reformat than i thought (creating an install cd with all the hotfixes slipstreamed and tweaked just the way i liked it took a long, long time, and in a room with no a/c, not very pleasant)anyhow, i'll be installing sonicstage tonight (seeing as how the latest attempt to get some form of a/c working has failed) and i'll let you know how it goes. Quote Link to comment Share on other sites More sharing options...
kiryen Posted August 6, 2005 Author Report Share Posted August 6, 2005 (edited) yeah, you'll still need to edit the registry (don't have a net md, so i didn't use the second part of the hacks, i only used the region change.)text will show up fine on sonicstage, but won't appear correctly when transferred to hi-md unless the region in the registry has been changed to 40000 hexdecimal. Edited August 6, 2005 by kiryen Quote Link to comment Share on other sites More sharing options...
